Help!! PICS How to get off Totall Gutted/Ripped oil filter off the thread??
So i am going to the chargers/broncos game today in person, first nfl game i have ever gone to, should be fun.
Maybe when i get home i will continue working on this, if not, then i will start first thing in the morning tomorrow and post updates to my status with this oil filter battle.
i do appreciate the comments and the help, thanks.
Have you asked it nicely to come off please?
When things get stuck on me I always try to turn it opposite to "break the seal" then try again. After working it back and forth a few times it nomally will break loose.
Big thanks to you gex!! but thanks to everyone else also for ideas and comments.
Yes, just got it off 5 min ago, took some pics that i will post in about an hour or two.
I used the air hammer method, rip what was left around the thread of the oil filter, that part came off, then i unbolted the plate and i am just going to go buy a new one.
Do you know if the part number for that is 3952301?? cause that is what the dealership said but the number on the part i have is 3952302 which shows up as unavailable now.
I've read that you can use a adapter from any SBC motor that will allow you to run a much larger oil filter instead of the LT1 filters. I'm sure a search will pull up that info. Congrads on finally getting it off. I just finished pulling pacesetter LT off a transam I bought what a PITA!!!
Jason
Jason
Jason
Jason
How large? AC Delco makes a quart size filter. I believe the part number is 1284.
Jason
Jason
STP S5, or Mobil m-302 i think are the two i use.
I had some problems with FRAM filters being very difficult to uscrew, and in the most severe case, I traced it down to the threads on the filter being so poorly cut that they galled the filter adapter threads.
