Help!! PICS How to get off Totall Gutted/Ripped oil filter off the thread??
what the hell did they use to tighten that filter anyway? the long flathead screwdriver/hammer (carpenter hammer.. not a rubber mallet) should do the trick. If not then you can bend down the filter, find the bolts holding the oil filter adapter plate onto the block and unbolt it that way. Not sure how you'd get it off after that. Perhaps just buy a new adapter.
What happens if you pull straight down on the metal edge where the gasket is? Does it pull away from where the gasket seals or just stick to it? That will tell you if it is the threads causing the problem or the stuck gasket.
Holy crap!! I've never seen a filter that was that destroyed and didn't come off. I think if you just keep doing what your doing it HAS to come off. If you get anymore of the filter off you'll be able to just remove the whole adaptor by removing the two bolts that hold it in place. Then I might just buy a new adaptor at that point depending on what shape it's in.
Good luck,
B
Good luck,
B
however, the problem i am having is that the chisel method is taking forever, i have only cut through 1/5 of the circumference around the thread, is there any other tool i can use to cut around the thread without damaging the block or anything else i need down there??
Good luck,
B
Good luck,
B
When you get it off, and get over the frustration...
You should post those pics on some other forum and tell people you started the car up and heard a big "bang" and then there was oil under the car and you found that...
It's rare that I actually laugh out loud at something on here but that's freakin' hilarious! I can see the 18 pages of ridiculous commentary and "root-cause analysis" already....that's awesome man...would be quite entertaining.
For next time: I found a swipe of grease on the seal and only tightening hand tight is the best way to keep from getting these issues.
I vote the chisel method. Unfortunately, that top part is thicker stamped steel so it is difficult to pull that seal away from the seating area
Something that I've done before in a situation similar to yours and it worked, screw two "self tapping" bolts (maybe 5/16" x 2" long) into two of the holes in the filter plate. Then fabricate some form of T-bar on a shaft that will engage to two bolts and then you can place some real torque on the filter plate.
You may ruin the bypass plate (tips of the bolts may hit the plate) but that is cheap. Be sure to put some grease on the gasket next time and don't over tighten it.
WD
WD
I think I would carefully use a dremel to cut between the holes and flush clean the base afterwards. I'm all but positive the filter is stuck at the gasket. Once the outer ring is free the threaded part should spin right off as said above.
Some people don't realize filters are to be one hand tightened and they should coat the rubber gasket with clean oil before installing. Although I've seen a lot of threads about this situation, this is the first (and best) with the pictures.
I figured i was stuck and had to post pics to see if anyone had any easier methods, even I look at the filter and just say OMFG as i try to work it off.
