Help!!! Pcm???
Old May 21, 2005 | 09:52 AM
Here4Beer's Avatar
Help!!! Pcm???
Just climed into the old girl and turned the key and my rpm's went to 1500 @ idle, check engine light on and the cooling fans are running. Did I just loose my PCM??
Things I did to remedy problem:
Disconnected positive battery terminal for 15 mins to reboot PCM, NO LUCK.
Checked all sensor connections. TIGHT.
So much for going to a car show today.
Any help is much appreciated.
95 Z-28 Medium Quasar Blue
21,800 original miles
Holley 52mm TB
Giggliotti G2 intake plenum
K&N Stage 2
160 Stat
LT-4 knock sensor
Goodyear RSAs on ZR-1 wheels
Old May 21, 2005 | 09:57 AM
Re: Help!!! Pcm???
Its VERY rare to lose the PCM. Have it scanned and the code will tell you what's wrong. You will have a problem getting your 95 scanned, since its an OBD-I PCM with an OBD-II 16-pin ALDL connector. Most shops don't understand, and try to hook up an OBD-II scanner.
Old May 21, 2005 | 11:06 AM
ZMAN Z28's Avatar
Re: Help!!! Pcm???
Did your car start and stay running? If it did, then it isn't the pcm.
Z
Old May 21, 2005 | 01:58 PM
Here4Beer's Avatar
Re: Help!!! ECM???
Sorry for the earlier post I meant ECM not PCM.I was pissed when I was typing and must have had a brain fart or something.
Yes the engine stays running but there is something wrong and I think the ECM is bad. Will have to get someone to run an OBD-I code on it.
The only thing common to the cooling fans and the rpm is the engine computer correct??
Old May 21, 2005 | 02:01 PM
Here4Beer's Avatar
Re: Help!!! Pcm???
Fred will a dearler be able to scan it??
Old May 21, 2005 | 04:21 PM
Re: Help!!! Pcm???
The ECM and PCM are the same thing. Up through 1993, it was called the Engine Control Module. When they added the 4L60E A4 and "skip shift" to the M6 in 1994, it became the Powertrain Control Module.
A dealer can scan it. They "should" know about the issue with the ALDL connector. There are scanners available like the AutoXray that have an adapter plug for the 95's. You can use a "Scanmaster" scanner, that doesn't use a plug, but simple wire connections, or you can get software like TTS DataMaster or FreeScan for free, as long as you get the correct wire harness to connect your 95 to a laptop.
Old May 23, 2005 | 10:52 AM
VintageMuscle's Avatar
Re: Help!!! Pcm???
The first thing I would do is remove that LT4KM and put in the correct LT1KM. Then go from there.....
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
