Help! Overheating!!!
Old Apr 21, 2013 | 05:57 PM
mikemassi's Avatar
I recently swapped a motor in my 94z and after everything was finished I bled coolant and I've done it about 15 times and car still over heats, no heat out vents, and overflow sprays out like a fountain. I have the two little hoses near rad cap in right places and all other hoses seem to be in right spots. Head vent tube bottom and resivoir is top. It seems the car over heats just after 5 min of idle on a cold start after sitting all night. What should I do?
Old Apr 21, 2013 | 06:05 PM
Re: Help! Overheating!!!
Sounds like the t'stat isn't opening.
Old Apr 21, 2013 | 06:42 PM
mikemassi's Avatar
I thought the same thing as well. So I removed the t-stat completely and it still doing the same thing. I'm leaning towards the water pump being bad?
Old Apr 21, 2013 | 06:54 PM
mikemassi's Avatar
I just think it's strange it heats up in literally less then 5 min. And by heat up I mean 240 on temp gauge
Old Apr 21, 2013 | 07:06 PM
RamAir95TA's Avatar
Sounds like the water pump isn't spinning.
Old Apr 21, 2013 | 07:14 PM
Look into the top of the radiator withe the cap off and see if coolant is pouring in from the steam line.
Did you put the water pump coupler on?
Old Apr 21, 2013 | 08:19 PM
mikemassi's Avatar
No coolant coming from steam line. And what do u mean by the water pump coupler?
Old Apr 21, 2013 | 09:24 PM
If your system is properly filled and you see no coolant from the steam line, the pump may not be working. If you don't know what the coupler is, chances are you did not put it on. It couples the pump to the drive gear. No coupler, no pump action.
#39
Old Apr 22, 2013 | 01:09 PM
96z28_lt1's Avatar
saw something like this the other day on ls1 tech, guy kept complaining his car was over heating and swore up and down waterpump was probably bad took it off and realized he forgot to put the coupler on
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
