help, oil pressure went to zero
Old Oct 9, 2003 | 01:59 AM
  #16
Zepp's Avatar
My guess is that you spun a camshaft bearing. I went through the same thing with my motor. The pressure is good at first because the oil is thicker when cold. As soon as it heats up it is thinner causing less oil pressure.
To prove this, try putting in something like 20-50 or better yet Straight 60 weight. It will keep better oil pressure for longer. Depending on how bad the motor is.
My advice though. Do not drive it anymore!!! When mine spun it scored the heck out of the block. I ended up having to get another block because it would have cost more to try and fix the block then to get a used one.
Good luck.
Old Oct 9, 2003 | 03:04 AM
  #17
edg1957's Avatar
Ditto here, I was just thinking the exact same thing. I think you have major engine issues, time for the 383 stroker
Ed
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
