Help o2 sensor problem!
I believe that the threads on my driver side header are stripped. The sensor will not tightly screw in. I can turn it all day, and it'll never tighten. I also can't seem to shake an engine code, and I'm guessing this is why. Is there any way to easily repair this problem?
These are also not the stock headers, they're shorty aftermarkets (if that should matter).
Re: Help o2 sensor problem!
You can buy O2 bungs from Jegs pretty cheaply. Buy em. Cut/grind the old one out, and weld in the new one. Screw in the new sensor. It really shouldnt take that long. Just make sure your a decent welder cause you dont want to "blow through" the headers
Are the headers "coated"? Sometimes the coating will prevent the threads on the sensor from engaging the threads on the sensor bung. If thats the case, its simply a matter of cleaning up the threads on the bung.
I just ran into this problem with my SLP's last night and need to know what is the size of the tap??
