help with no idle problem please
Old Jun 23, 2007 | 09:21 PM
one eyed willy's Avatar
well i just got it all back together.i have a weird problem though.
i have zero idle,car wont start unless i hold the pedal.it gets stranger,my first attempt at starting it went fine.started up and held the idle for 15 minites.i changed the oil to make sure everything got out and now it wont idle.while i was changing the oil i pulled th passenger valve cover to check the rr's and to make sure everything was good.
i have a bbk TB,egr,evap and smog pump are all deleted from the PCM.i just plugged the evap line with a bolt and stuck it back in the wire loom.
its just a hotcam.when i first started it,it idled fine,the coolant light was on because i had not purged the hoses yet,oil pressure is great,temp seems very low.
160 thermo,fans come on sooner with the tune.
it does not stumble or idle rough,it just wont idle AT ALL,if i press the pedal it will start right up,and i can keep it going by fethering the pedal.i can get the temp up to around 180,let off the pedal and it still just dies.
this is everything i did:
changed plugs and wires
headers and dual exhaust
new intake gaskets
lifters,pushrods,hot cam kit with RR's and springs
extended the o2 for the headers(they have 2 brown wires and could have been mixed up when i put them back togther)
cold air intake
vortech elbow
58mm TB w/ ported manifold
mad28 tune w/ all emissions deleted
i drove the car around and it hauls ***,but at every stop sign it would just die.
i have looked over everything,and all the connections.i cant see anything coming loose and all the vacuum hoses are tight.for now i just have the throttle cable adjusted to hold the flappers open a little.
any thoughts?
Old Jun 23, 2007 | 09:46 PM
OBE1 95Z28's Avatar
Possibly a bad Idle Air Control sensor or the harness going to the sensor. You can have the car scanned and see what the IAC counts are.
Old Jun 23, 2007 | 11:07 PM
yup,thats what it is leading to.so if i take it to auto zone or somewhere they can scan it and tell me the counts?
Old Jun 24, 2007 | 12:48 PM
How about some basic data about the car..... like the year? That will determine how the car can be scanned and who can scan it.
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
