help new owner
Old Apr 19, 2003 | 09:11 PM
will483's Avatar
help new owner
I just bought a 94 z28 with a six speed. it has a couple mods, but i dont think its much. I am new to the lt1, but i do know a lot about cars. so here is a list of beginer questions. Here is my setup thus far. MSD ingnition, taylor wires, champion plugs. other than that straight up stock. How does it look for starters. i just replaced the cap rotor and distributor 642 dollars for parts. did i replace what everybody is refering to as the "opti" i have never seen a ditrib behind a water pump. are the components thus far good. i think the first thing i will do is change the plugs. i have the six speed tranmission. is it good adn what is it called. what are my gear ratios in the rear end? any other information on the car would be greatly appreciated. by the way had to replace the distrib because bearing went out and melted everything. i have never seen a distub cap that cost so much. anything else i should replace for starting out. 110,000 miles. thanks for any advice and input. i would appreciate all comments
Old Apr 19, 2003 | 09:20 PM
Fbody1's Avatar
the rear gear ratio should be a 3.42 with the m6(six speed)
Old Apr 19, 2003 | 09:30 PM
Fbody1's Avatar
sorry the trans is a borge warner T56(six speed) , and the cap and rotor that you are talking about for that kind of $ sounds like a new (opti) optispark, wich is the distribitor for these cars , you should look at the water pump(just above the opti)there is a small hole in the bottom of it , make sure it is not (or has been)driping or leaking from this hole, if it has it will ruin the opti(they dont take to water too well) so with that many miles i'd watch it , hope this help's you out
Black6SpdTA's Avatar
Re: help new owner
o its awesome. one of the best trannys. basically same one in vette, cobra, and viper. call T56
Old Apr 19, 2003 | 10:28 PM
Sorry that you did not know you could get a brand new GM distributor (cap, rotor, housing) complete and ready to bolt on for ~$300 for your 1994.
Use these guys for your GM parts needs and you will never be ripped off:
Dal Slabaugh: 877-448-5451
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept)
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Old Apr 19, 2003 | 11:12 PM
chasmanz28's Avatar
yeah dude if you have a ? come on here first before you buy expensive parts, lots of good help on this forum
Formula Steve
Sep 19, 2023 08:31 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
cmsmith
Sep 14, 2015 09:09 PM
