help me build my engine
Old Jul 23, 2003 | 11:21 AM
  #16
thewinner's Avatar
2500 for a turbo setup, ya right. A grand would not get you the other stuff. how about the aftermarket computer? thats 2k in itsself.
Old Jul 23, 2003 | 11:37 AM
  #17
FacelessZ's Avatar
Complete p/p heads by Lloyd ($1,200), cam, stall (if A4), 3.73's and call it a day...for now...
Old Jul 23, 2003 | 11:45 AM
  #18
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
no offence to lloyd,
but i dont think his heads will make 450rwhp. I may be wrong. But for his goals i'm not really thinking stock head castings.
Old Jul 23, 2003 | 11:49 AM
  #19
FacelessZ's Avatar
Never said his heads would make 450rwhp...but for the price it'll but you past 400...
Stock head castings are just a suggestion...
Old Jul 23, 2003 | 11:51 AM
  #20
rob97ss's Avatar
unless you plan on doing everything your self dont forget labor?
Old Jul 23, 2003 | 12:13 PM
  #21
ZPaul2Fresh8's Avatar
What's wrong with editing your current PCM? FAST system can be bought for $1200 if needed...
I said $2500 would be scraping the tip, but would put him far on his way...
I dont think he's into forced induction anyway.. but it would get you 450rwhp if you went with an easy S/C.
Old Jul 23, 2003 | 12:32 PM
  #22
thewinner's Avatar
all about bang for the buck.
you obviously know nothing about a turbosetup on an lt1
2500 wouldnt even scrape the surface let alone put him far on his way.
Old Jul 23, 2003 | 12:34 PM
  #23
Chris'SS #2152's Avatar
Someone mentioned stall for A4, he has m6 so a stage 3 clutch is necc. for sure to hold that power.
I would start off with doing exhaust mods. LT's/y-pipe or x-pipe and cat back. Then move into the thnigs needed to support the engine.
Fuel system only needs a 255lph intank so that's not bad.
Then engine:
Heads
Cam
Rocker Arms
pushrods
guide plates
lifters
gaskets
new wires/plugs/02's and extensions
Timing chain
waterpump while your their.
This will take care of the top end. Bottom end is endless
Pistons
Rods
bearings
oil pump, etc.
Also you'll want to keep in mind you'll need a new rear end with that much power!!!!!
Also, labor will set you back at least 2K + dyno tuning.
I'd start out with a baseline dyno of your surrent set up and break out your goals from there.
Old Jul 23, 2003 | 12:55 PM
  #24
<-- Please educate me, since you know more than me. How's come?
Bearmans
Dec 3, 2014 05:28 AM
guionM
10
Sep 8, 2002 11:08 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
steve10358
Aug 1, 2002 01:05 PM
