HELP!! is this a LT1 thermostat or not????
Old Aug 3, 2007 | 08:50 PM
tnmotown's Avatar
I just ordered a Hypertech *160 t-stat from summit the other day, part number HYP-1005, and when i took out my old one they were different!! The old one sat fine on the water pump housing and now this new one from hypertech seems smaller and just "dropped" right in the water pump. It didnt even sit on the housing or nothing. Now im pretty sure but is it a wrong t-stat? When i search summit i did put all my specs, i.e. 94 camaro z28 5.7L. I want a *160 thermostat so does anyone know of a correct one that i can order?
Old Aug 3, 2007 | 08:53 PM
94_PatriotRed_Z's Avatar
no you need hyp-1008
Old Aug 3, 2007 | 09:02 PM
tnmotown's Avatar
got it, thanks patriot
Old Aug 6, 2007 | 05:27 AM
Guest47904's Avatar
Guest
You'de be better off using a lower temp switch for the fans. http://store.summitracing.com/egnsea...4+115&x=41&y=7
Old Aug 6, 2007 | 09:10 AM
tnmotown's Avatar
yeah i just installed a SLP manual fan switch as well. it works great now
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 27, 2014 09:41 AM
cristian1311
Nov 23, 2014 02:22 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
