HELP!! I dont know whats wrong?!?!
Old Jun 18, 2005 | 02:20 PM
slp97camaro's Avatar
Question HELP!! I dont know whats wrong?!?!
I have a 97 camaro ss, and somethings wrong with my car, because when i get into high rpm's in first gear, then shift into second, it makes a loud popping noise? i have no clue what it is...and its like the whole trans is moving, but i checked the mounts and replaced them, so its not that...
Old Jun 18, 2005 | 02:22 PM
n2ceptor's Avatar
Re: HELP!! I dont know whats wrong?!?!
U-joint???????
Old Jun 19, 2005 | 09:30 PM
pretty sure its not the u joint, but good idea...does anyone know how many trans mounts lt1's have...w/ the 6 speed?? is there on the drivers side of the trans?? because it looks like that side of the car like goes down??
Old Jun 19, 2005 | 09:59 PM
Dave89IROC's Avatar
there are 2 engine mounts, and 1 trans mount, however, did you inspect the torque arm bushing/mount?
Old Jun 20, 2005 | 07:48 AM
89385formula's Avatar
Could very well be the tranny mount or the torque arm mount. You might as well replace both with decent poly units and be done with it. That should fix the problem and stiffen the drivetrain a good bit as well.
Old Feb 1, 2006 | 09:42 PM
317indy's Avatar
I had a bolt pop out of the torque arm once, it made hit the bottom of my car HARD as **** any time I would hit a bump. It scared the **** out of me, so Im sure its not the torque arm.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
