Help with guideplates
Old Jan 9, 2009 | 05:15 PM
dubbsix's Avatar
Okay im fricken confused. I bought some manely guideplates to go with my nsa 1.6 pro mags, but I read that depending on the placement of the guide plates it maybe necessary to loosen the rocker stud and adjust them so the push rod is position correclty -- is that right?
So should i bother with screwing the studs in and installing the guideplates before i put the heads on and assemble the rockers since i'll probably have to loose an adjust them anyway?
I should have just bought SA pro mags?! <-- anyone wanna trade?
Old Jan 9, 2009 | 07:35 PM
Green96Z's Avatar
Which guideplates did you buy? Are they adjustable?
Old Jan 9, 2009 | 10:57 PM
Sinister95Z's Avatar
When we installed my guideplates, almost all of them were lined up perfectly right from the start. There is not much room for error. IF you have to adjust them, it is only a very tiny bit. One way to make this even easier is to use ARP studs. They have guideplate locater shanks at the top of the base threads.
Old Jan 9, 2009 | 11:13 PM
dubbsix's Avatar
They are not adjustable. The package says manely 5/16
Old Jan 9, 2009 | 11:15 PM
dubbsix's Avatar
Oh.. well i already bought some studs.. but hopefully things line up.
Old Jan 10, 2009 | 12:22 AM
You should be buying plates that are specifically ok for the LT1 (or adjustable)-not plain SBC plates. This, with plate suggestions, is mentioned in about every thread around about guideplates. Hope does not always get them lined up right.
Old Jan 10, 2009 | 01:41 AM
dubbsix's Avatar
I will reference the part number. My machine shop bought them for me.. and they knew it was for an lt1 but i will double check.
Old Jan 10, 2009 | 09:18 AM
A lot of shops think they are the same. Don't rely on them to be right.
Old Jan 10, 2009 | 11:13 AM
CamaroBoy96Z28's Avatar
i second this. Happens all the time with the LT1. I run GMPP guideplates because there's no need to adjust anything, they are for the LT1. Shoebox has the GM part number for these.
Old Jan 10, 2009 | 02:19 PM
If you do have to buy new guideplates, alot of people including myself are using the Trickflows. Good guideplates and very well priced.
Old Jan 10, 2009 | 04:53 PM
lt1-xjs's Avatar
Originally Posted by sinister95z
if you do have to buy new guideplates, alot of people including myself are using the trickflows. Good guideplates and very well priced.
tfs-30400623-8
wytblur
Oct 29, 2003 08:01 AM
onebadponcho
Oct 20, 2003 01:44 AM
MattysTA
Oct 5, 2003 08:53 AM
94formulabz
Aug 27, 2003 03:43 AM
94formulabz
Aug 15, 2003 08:50 PM
