HELP, Fuel rail...
Old Feb 15, 2008 | 02:06 PM
96supersport's Avatar
HELP, Fuel rail...
how in the hell do i disconnect the hard lines from the back of the fuel rails.
i have the quick disconnect tools thats the only thing holding me back from finishing this intake gasket.
Old Feb 15, 2008 | 02:12 PM
jchevy's Avatar
I have the cheapy plastic disconnect tools from autozone, the smaller return line come off easy for me, but the supply line is a Bitch, I have to keep messing with it. I just recently replaced my fuel lines to the rail, and the supply line is still a pain.
Old Feb 15, 2008 | 03:22 PM
Big Lebowski's Avatar
Hey, Just push the tool all the way until it stops. Then pull the line off. Sometimes they can be a pain. I found rotating the tool around sometimes works. There are four or five tabs inside the lines, they must ALL be held out for the lines to disconnect. Keep with it and you will get it.
Old Feb 15, 2008 | 04:00 PM
ss.slp.ls1's Avatar
Just keep at it. Make sure you are pushing the lines towards the rail and disconnect tool, and not just yanking on the disconnect tool.
Old Feb 15, 2008 | 06:10 PM
i went to advance auto parts and bought the mucho expensive, aluminum quick disconnects, and they came off with easy.
cheap plastic ones wouldnt even budge the lines
Old Feb 15, 2008 | 06:13 PM
jchevy's Avatar
I need to get some of those too.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
tbyrne
Jul 2, 2002 05:37 PM
