Help With Fuel Delivery
Old Jul 6, 2005 | 04:49 PM
95HellBird's Avatar
Ok my firebird just decided to be an butt the yesterday, i was at work and went to leave and my car wouldn't fire, it doesnt start up unless i pour gas into the throttle body then it'll fire up, i cant find my fuel filter, i know its in-line i hope its not my pump cuz i gotta FULL tank of gas and i dont really wanna drop it out to change my fuel pump if its just the filter...does anyone know where its located on a 95 Formula Firebird????????
Old Jul 6, 2005 | 05:09 PM
1993Fast_Z's Avatar
Re: Help With Fuel Delivery
well, i dont know exactly where it is located on a Firebird, but i have had this problem with my car and it turned out to be the Fuel Pump...a good way to test your fuel pump is to get a buddy or someone to get in your car, and turn it over while you beat on the center of the gas tank with a rubber mallot...it should start and then spudder around until it dies...and just keep repeating that, if it does that over and over again, its definately your fuel pump...hopefully someone else can help you on location of your fuel filter...
Old Jul 6, 2005 | 05:20 PM
94zLT1's Avatar
ummmm please dont beat on your gas tank..the fuel flilter is by the rear wheel of the drivers side on the fuel line
Old Jul 6, 2005 | 05:21 PM
95HellBird's Avatar
Exclamation Re: Help With Fuel Delivery
Thanks i will try it, i let it sit for about 12 hrs thinkin i mighta flooded it but??? it did start up again but just for about a second then died and went back to cranking but no firing....fuel pump, filter, line, or all of em?
Old Jul 6, 2005 | 05:23 PM
The filter is on the drivers side rear subframe, right in front of the wheel/axle. Its in the same location as the red billet filter in this pic, but it isn't going to look like the billet filter, it will be a silver metal "can" with a line and a line out.
http://cjcfo.fbody.com/members/injun.../DCP03675a.jpg
Do you hear the fuel pump prime for 2 seconds when you turn the key to "on"?
Do you have a fuel pressure gauge - easiest way to check.
Is the SES light on? If the Opti is putting out the low res pulse signal, the PCM shuts down the fuel system. A scan would show DTC 16 if that's the case. Might be worth flashing the codes on your SES just to check.
Old Jul 7, 2005 | 09:04 PM
95HellBird's Avatar
Ok, Its not the filter, changed it out still didnt start up....so i changed out the fuel pump with help from Worldisround.com but seriously that pump was a B!Tc# to change out
Last edited by 95HellBird; Jul 13, 2005 at 08:17 PM. Reason: changed but didnt want to post another thing
DirtyDaveW
Dec 1, 2016 05:37 PM
944LT1
Jun 24, 2002 10:36 PM
