Help!!!electrical Problem
Old Nov 23, 2005 | 09:48 AM
charlezd71's Avatar
Angry Help!!!electrical Problem
Okay I keep blowing the fuse for my interior lights (dome) and the trunk lock remote button. All of the guages and the dash lights work its just the accessory lights. I cant seem to figure out whats causing this. It happened rite after I replaced the electronic ignition switch and now the a/c wont work either. checked the wires and nothing is touching and everything is reconnected, can only be connected one way so I know its on rite. Please help its totally dark in here
Old Nov 23, 2005 | 10:50 AM
BUBBA's Avatar
Re: Help!!!electrical Problem
So if you replace the fuse, when does it blow: when you open the door or when you turn your dome light on? Is the AC fuse the same as the dome lights? Most fuses blow when you ground out the hot wire. If it didn't do it until you swapped the ignition, then you apparently did something wrong (at least I would consider that possiblility and take a look.) JMHO
liamcg97
Nov 25, 2019 05:55 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
