Help compute compersion ratio
Old Aug 19, 2004 | 02:06 PM
Zrag's Avatar
Help with computing compresion. This is the info I have...
stock heads that were milled .10s planing on using .29 impala
head gaskets, Stock bottom end.
Please help...
Old Aug 19, 2004 | 02:27 PM
Mindgame's Avatar
Re: Help compute compersion ratio
Need to know the combustion chamber volume. Are you sure about that .100? Or is that .010 (about 3 hairs)?
I don't think .100 is what you meant. With the .029 gasket and stock bottom end I get 11.25:1 static.
edit: miscalculation on my part... my spreadsheet defaults to 4.03 bore. Made the correction.
-Mindgame
Old Aug 19, 2004 | 08:54 PM
Zrag's Avatar
Thanks yes it is .010 again I've got the stock bottom end bore/stroke the same, valves are dished more than stock but again planing to use .029 gasket.
If it is 11.25:1 ratio wow that is a bit higher than I wanted, just in case in emergency etc I want to be able to put in reg gas. I want 11 to 10.5.
THANKS
Old Aug 20, 2004 | 08:56 AM
Zrag's Avatar
ttt anyone...
Old Aug 20, 2004 | 09:48 AM
rskrause's Avatar
Moderator
Originally Posted by Zrag
ttt anyone...
Not sure what you are looking for at this point?
Rich
Old Aug 20, 2004 | 12:36 PM
Zrag's Avatar
Question is the where do I need to be in head gasket to make the 10.5 or so comp ratio .035 then? I just don't have the graph to calculate it all.
Old Aug 21, 2004 | 07:13 AM
Zrag's Avatar
ttt...again
Old Aug 21, 2004 | 07:50 AM
rskrause's Avatar
Moderator
http://www.kb-silvolite.com/calc.php?action=comp
Rich
Old Aug 21, 2004 | 08:20 AM
Zrag's Avatar
Rich thanks...but when I try the link I get an error for Waol caused error and will now close...and no page is displayed...thx
Old Aug 21, 2004 | 08:41 AM
LWM's Avatar
LWM
You have mail
LWM
Old Aug 21, 2004 | 10:09 AM
rskrause's Avatar
Moderator
http://www.smokemup.com/auto_math/compression_ratio.php
Rich
13qtr
Oct 28, 2016 08:11 PM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
