help with compression
Old Jul 16, 2007 | 07:46 PM
DSM PImp's Avatar
These are my specs and the compression i got.
Cylinder Bore: 4.03
Stroke: 3.75
Head Gasket Thickness: .039
Combustion Chamber Volume: 58
Piston Dome: -7
Deck height: 0.025
The compression value i got was"10.951544491739458:1"
I used this calc http://www.csgnetwork.com/compcalc.html
I want to make sure every thing is correct. Not sure on the reliability of that calc either
What do you guys think.
Old Jul 16, 2007 | 08:54 PM
rskrause's Avatar
Moderator
Gasket bore?
Assuming it is 4.03, the CR is ~11:1
Rich
Old Jul 16, 2007 | 09:16 PM
DSM PImp's Avatar
oops forgot that. the fel pro gasket would be at 4.125
Old Jul 16, 2007 | 10:53 PM
rskrause's Avatar
Moderator
Then you gots it right.
Rich
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
