Would 10w 40 Penzoil or Mobil 1 Fully Synthetic Oil Hurt my Car?
Hi Guys!
I had a 1997 Camaro Z28 and the valves seemed noisy especially when it warmed up. When it was cold it seemed fine. Oil Pressure was 30psi on it warm.
Now I have a 1997 Formula with 20K miles it hold about 25psi warm. Both cars have noisy lifters except when cold.
I wonder if this is normal for these cars? WOuld it hurt to use 10w 40 a little heavier oil?
Need input guys.......These newer chevy engines in the truck are quiet.
Thanks Lee!
Thanks Lee!
Won't hurt it.
I like Mobil 1 in the daily drivers but I've noticed the viscosity on Mobil 1 isn't very stable, it varies more with temp than other oils. Racing my car with Mobil 1 led to more valvetrain noise and lower pressure, I don't recall the temps off the top of my head.
The expensive "snake oil" of RedLine seems to work good on my LT1. I haven't done any oil analysis though.
Check out BITOG for an interesting forum dedicated to lubricants.... though there's plenty of salesmen there
Hi Guys!
Thanks Lee!
Thanks Lee!
I use mobil 1 10w-30 fully synthetic in my car and i have for the last 6 years with no problems and no leaks.when i park it for winter i put 10w-30 regular Quaker state oil and run it for a few hundred miles after i first get it out and then switch back to mobil 1 and still no problems with leaks.
