Help The Clutch Will Not Disengage Fully (Street Twin)
My clutch will not disengage fully. I put the Mcleod in everything is in place. We go to put it in gear and it will go into gear with some grinding. It's very close. Does anyone have the instuctions on a link. I would like to double check the torque and shim spacing.
Yep I installed the master and bled the system. Here's the deal, we had the clutch instaled and it worked fine. Had to pull the tranny out for another problem and reinstalled everything. Now it will not fully disengage.
Ringmaster72
Mar 19, 2015 03:32 PM
