HELP! Car won't start suddenly!!
Old Apr 22, 2003 | 05:20 PM
FRDEATR's Avatar
HELP!!! CAR WONT START!!
I had my car parked out in front of my friends house last night. Well it rained all night, and when I went to pick it up this morning, it wouldn't start. I turn the key and nothing happens. My lights, windows, and stereo all work. My battery guage shows 13. Any ideas? All help is greatly appreciated. I need my car! Thanks,
Brian
Old Apr 22, 2003 | 07:54 PM
FRDEATR's Avatar
ttt
Old Apr 22, 2003 | 08:36 PM
kjlvilla's Avatar
When you say nothing happens do you mean no clicking or cranking? If it doesn't crank and the security light isn't on then try tapping the starter. If your security light is on then you probably have a theft deterrent problem. Try a spare key. If this doesn't work and the starter doesn't sound like it's trying to work, and it's an auto, try pulling the shifter into neutral and starting the engine. If its a manual then try push starting it. Good luck.
Old Apr 22, 2003 | 08:52 PM
Z95m6's Avatar
i would say either your clutch switch the one when you push down the pedal to start the car or your ignition switch.
Old Apr 23, 2003 | 12:18 PM
FRDEATR's Avatar
It started today, but it wasn't normal. I was holding the key in the "Start" position for a second or two, and then the starter kicked in and it cranked. I already checked my clutch/neutral safety wires, and they're not the problem. Now it has a delay before it will try to crank. Any ideas? All help is appreciated. Thanks,
Brian
Oh yeah, my car didn't come with the stock security system either.
bfmv13trivium
Jan 14, 2015 09:57 AM
Britbilly
Jan 7, 2015 08:49 PM
Ricardo
Nov 29, 2014 10:58 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
