help car poping
Old Jul 12, 2008 | 04:19 PM
  #16
ss.slp.ls1's Avatar
The vacuum line to the opti just vents ozone from the high voltage side of the opti. if you got moisture in the opti, you might get lucky and it will dry out. But if it doesn't and it continues to pop, I would strongly recommend changing the whole thing and not just the cap and rotor. That is if in fact the opti is found to be the culprit of course.
Old Jul 12, 2008 | 08:47 PM
  #17
camaro1fastz28's Avatar
yea i think i am going to order a new opti there goes 500 to the dealer
Old Jul 12, 2008 | 10:27 PM
  #18
tlillard23's Avatar
OPTI's
summit has them for $300. look around, i think there is a guy that sells them at dealer cost....
Old Jul 13, 2008 | 03:17 AM
  #19
o yea last time my opti went 2 year ago i spent 500 at the dealer cause i want oem
Old Jul 13, 2008 | 03:53 AM
  #20
SS RRR's Avatar
Originally Posted by camaro1fastz28
i have changed the plugs 3 times and it a new set of wires it would pop at idle if i had a wire crossed it only pop under a load
Not necessarily.
Old Jul 13, 2008 | 04:29 AM
  #21
tlillard23's Avatar
If you do a search for opti prices, You can get OEM from other sources.
I will actually be calling Jason Cromer on monday for an Opti.
Old Jul 13, 2008 | 02:14 PM
  #22
what he prices like
Old Jul 13, 2008 | 04:27 PM
  #23
tlillard23's Avatar
i'll tell you on monday!!
Summit has OEM (AC Delco) for 300, so I assume Jason has them for about 260/280?
Old Jul 13, 2008 | 08:31 PM
  #24
ss.slp.ls1's Avatar
If you want genuine OEM opti's you can get them from "thepartsladi" on ebay. I have bought from her twice. I got an AC Delco opti for $280 shipped and I bought a Delphi (also OEM) for a buddy for $230 shipped. They both came in original packaging and arrived in about a week. Prices can't be beat.
Old Jul 14, 2008 | 01:25 PM
  #25
tlillard23's Avatar
I was wondering if the crank posistion sensor could cause this problem? I forgot to plug the sensor in and the car was poping and backfiring. I drove it for about 3 days untill I could get a scanner to read the codes. what is the chance that the CPS is faulty but not setting any codes?
FYI: I just ordered an opti from thepartsladi. we'll see what happens.
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
MJ_Z28
Aug 8, 2002 09:07 PM
96CamZ
Jul 27, 2002 04:13 PM
