help car poping
Old Jul 11, 2008 | 01:04 PM
camaro1fastz28's Avatar
Angry help car poping
i just got my car back toghter got it tuned no check engine light but when u give it more then 1/4 throtle it just pops no popping while idleing would no vac to the opti cause it to pop it a 96 m6 car with a small cam
Old Jul 11, 2008 | 02:05 PM
seawolf06's Avatar
Check the plugs wires two or three times to be sure.
Old Jul 11, 2008 | 02:08 PM
i have changed the plugs 3 times and it a new set of wires it would pop at idle if i had a wire crossed it only pop under a load
Old Jul 11, 2008 | 02:10 PM
ss.slp.ls1's Avatar
Popping out of the exhaust sounds like an ignition issue.
I would check your plugs, wires, coil, and opti.
Old Jul 11, 2008 | 02:13 PM
can the opti go bad from sitting in my garage for 2 years while my car was apart and do u need the vac source to the opti
Old Jul 11, 2008 | 02:16 PM
seawolf06's Avatar
I had 5 and 7 wires crossed and it idled fine, but as soon as you tried to rev it, it backfired. Swapped just those two and now it's perfect.
Old Jul 11, 2008 | 02:25 PM
this idel fined and u rev it it fine but as soon as u put a load on it it pops
Old Jul 11, 2008 | 03:26 PM
ss.slp.ls1's Avatar
Old Jul 11, 2008 | 03:27 PM
seawolf06's Avatar
Still an ignition issue.
Old Jul 11, 2008 | 05:14 PM
ttop1986's Avatar
Pretty much same story here, but mine were cyl 6 and 8. Check the wires again and again all the way from the opti to where the plugs.
Old Jul 11, 2008 | 05:15 PM
i am about to go buy a new opti if that dont fix it i am lost
Old Jul 11, 2008 | 06:46 PM
seawolf06's Avatar
Send me your old one. It's probably fine.
Old Jul 12, 2008 | 11:08 AM
ok connect the vac source to the opti and it better it not as bad of a poping but still pop every now and then i going to change the cap and rotor in the opti
Old Jul 12, 2008 | 11:22 AM
seawolf06's Avatar
You connected the vacuum lines up to the opti and it ran better? That's strange. Maybe got some moisture in there when they were off.
Old Jul 12, 2008 | 11:33 AM
mabe it got moisture in there from sitting my car does not see rain or snow i dont even drive it if the ground wet
