View Poll Results: which choice
option A
26.67%
option B
53.33%
option C
20.00%
Voters: 15. You may not vote on this poll
help on cam choice
Old Jun 24, 2007 | 04:43 PM
reamo04's Avatar
help on cam choice
alright, so, motors been on its way for a while now, and i finally want to get it done
a)242/248 584/579(with 1.5s)
b) 243/251 560/565 (with 1.5s)
c)neither
my goals are i want low 11's and decent streetability. I will be running probably a 3200-3600 stall, and 3.73 gears
Old Jun 24, 2007 | 07:01 PM
LSWHO's Avatar
B with 1.6s?
Old Jun 24, 2007 | 07:05 PM
reamo04's Avatar
yes, i will use 1.6 RR's, but those are the lift #s with the 1.5s
Old Jun 25, 2007 | 06:11 PM
reamo04's Avatar
anyone? Really would like to know what the common consensus is before i order one.
option A with 1.6 is: 623/618
option B is: 597/603
Old Jun 25, 2007 | 07:12 PM
rskrause's Avatar
Moderator
Those cams, assuming similar lobe profiles and lsa, are within a gnats hair of each other. They are also both high lift for street cams and you better have top quality springs to get decent spring life.
Rich
Old Jun 25, 2007 | 07:14 PM
mdacton's Avatar
what are the details on the engine?
not much info
Old Jun 25, 2007 | 08:30 PM
seawolf06's Avatar
I thought I posted it, but the lift on A is with 1.6 RR. Check the comp cams lobe catalog if you don't believe me. Summit isn't always right.
I chose the second cam, btw. I like the Lunati lobes a little better, for some reason... (hint: high lift and low lsa)
Old Jun 25, 2007 | 09:56 PM
reamo04's Avatar
yeah, im leaning towards the lunati. I will get w/e springs they recommend probably, or maybe some PACs or 941s. For drivability, would the 2nd cam (lunati 60123) affect it too much?
Old Jun 26, 2007 | 03:36 PM
seawolf06's Avatar
Well, that's a really big cam for the street, so yeh, I would say it would affect drivability a good bit. The springs they recommend for their cams seem to be very small. I think the one they said would be good for the 60122 had 100lbs of seat pressure? I would use beehives no matter what, though. They rev a lot better among other things.
Old Jun 26, 2007 | 03:41 PM
Rice Killer87's Avatar
What heads and compression are you trying to run?
EDIT:
Please keep in mind STREETABILITY is a relative term,everyones different.
Old Jun 26, 2007 | 04:24 PM
Bersaglieri's Avatar
not much info
-Dustin-
Old Jun 26, 2007 | 04:31 PM
mdacton's Avatar
Originally Posted by Bersaglieri
-Dustin-
all I see is 383 in the works.....
Old Jun 26, 2007 | 08:09 PM
reamo04's Avatar
sorry, it will be a 383, flat top pistons w/ -5cc valve relief, ported trickflow heads (64cc chambers)
I talked to a local car guru, and he told me the bigger cam (2nd one) and try to get it ground so i can do the 4-7 plug wire swap, and on like a 112 LSA instead of the 110, what do u guys think?
Old Jun 26, 2007 | 08:12 PM
my94blackz's Avatar
A on 1.6's. I like lift!
Old Jun 26, 2007 | 08:16 PM
mdacton's Avatar
4/7 swap isn't going to gain anything at that level of power.......maybe smooth it out, I don't see it being worth the money.
Why 64cc chambers?
