HELP! bad misfire on new plugs and Delteq!
Old Mar 22, 2005 | 05:20 PM
  #31
fade2blk500's Avatar
Re: HELP! bad misfire on new plugs and Delteq!
Definitely replace the plug wire if its burnt or cracked. It will make it run like **** if its arching. I know this from personal experience. It'll feel like a 4 cylinder!! lol
Old Mar 23, 2005 | 01:32 AM
  #32
1982z28with18s's Avatar
Originally Posted by disco192
Just buy 1" header bolts and blue locktite them. Along wiht a good header gasket (FEL-1406), that will put an end to all your problems.
Locktite on aluminum heads is a NO NO. Unless you don't want threads in your heads when you take out the bolts.
Old Mar 23, 2005 | 03:30 PM
  #33
pillagenburn's Avatar
Lightbulb Re: HELP! bad misfire on new plugs and Delteq!
Well, I did leave the optispark holes uncovered when i did the delteq (oops) - i.e. i didnt cap the spark plug wire holes with anything. Could this have caused moisture, dirt etc. to get up in the opti?
just a thought
and is there anything bad about autozone optis? or should i just get one from Jason?
I wonder how hard it would be to remove an optispark from the top? lol - not so hard i'd imagine (with a Delteq and all)
thanks!
Old Mar 25, 2005 | 11:41 PM
  #34
onthalolo's Avatar
Is the car still running like crap? I had a problem with a O2 ground wire on the egine harness. My car ran like s*** right from the start and stumbled so hard i couldnt get it up over 35 mph all because of a o2 ground wire short in the engine harness.
PCLZ28
Dec 24, 2015 05:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Ari G
Dec 11, 2014 03:21 PM
IRABuss
Sep 7, 2011 09:08 PM
