Help 97 dualcat Y pipe. Help.
Old Jul 7, 2005 | 10:46 PM
crazypurgatory's Avatar
Question Help 97 dualcat Y pipe. Help.
I'm trying to change out the pasanger side cat.
I need some help getting to the exhaust manifold Nuts.
I learnd the hard way that I have to take down the starter.
And then I can get a clear shot at that one.
I broke the stud on that one.
The second one is a clear shot.
The third one is the problem.
What do I need to get to it?
I have a BMR K-member so I know that makes things easer.
Thanks for any help.
Chris G.
Old Jul 7, 2005 | 11:29 PM
bluezed28's Avatar
Re: Help 97 dualcat Y pipe. Help.
I have a 96 (dual cats). I was able to get to all the nuts w/o taking down the starter but it takes some clever angles to get at it. I remember using a long extension and possibly a wobble extension to give me that extra angle. I actually broke all the studs and ended up drilling out all the studs and replacing them with galvanized bolts.
Old Jul 9, 2005 | 03:41 AM
TTT.
Old Jul 10, 2005 | 09:03 PM
Question Re: Help 97 dualcat Y pipe. Help.
Any body else?
I have to replace one of the studs on the exhaust manifold.
Are they pressed in or do the screw in?
Thanks,
Old Jul 11, 2005 | 02:38 PM
NBred94's Avatar
The studs on the manifold are pressed in, I believe, you could probably pick up a used manifold for cheaper than you could get your old one fixed.
Since you have the K-Member, long-tube header install should be a breeze, you should use this as an excuse to upgrade.
Old Jul 11, 2005 | 02:52 PM
Thanks,
I have a set of SLP shorty headers.
I just have to get them coated before I put them on.
I'm justing trying to replace the cat.
I got a used one at a good price.
But I'm having problems getting to then nuts.
Thanks for the info on the studs.
Chris.
Old Jul 13, 2005 | 12:17 AM
TTT.
anybody else.
Old Jul 31, 2005 | 09:51 PM
TTT
Any body else know what tool's to use to get the pasanger side cat down.
I have to get it down tomarrow it's killing my gas mpg.
Thanks,
Chris G.
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
truecontr3
Oct 11, 2015 09:30 AM
football4life
Oct 4, 2015 07:48 AM
surreybrad
Sep 29, 2015 09:00 PM
