Hello great site!! 96 LT1 Needs your help please
My 96 has all the sudden started missing bad. Where would you start?
New plugs and wires ect... also please let me know what brand is good.
I have read alot here about the Optispark and I think that my be the problem.
Is there anyway to have it checked out?
Thanks for any help.
Randy
Randy
Your OBD-II PCM includes the capability of counting misfires by individual cylinder number. If you have the PCM scanned with an OBD-II scanner, with "GM Enhanced" parameter capabilities, it will tell you which cylinder(s) are misfiring. That might point you in the correct direction.
I run Taylors and haven't had a problem with them. I would guess that plug wires have deteriorated and that is your misfire. Plugs and wires are never a bad idea. You might not be able to get the 8mm plug wires back into the stock wire location. I can't remember if they fit in the looms or not.
oldschool
Feb 9, 2016 09:21 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
People need to realize you can have problems with the best of brands.
