Hello great site!! 96 LT1 Needs your help please
Old Jan 9, 2007 | 01:20 PM
2tight's Avatar
My 96 has all the sudden started missing bad. Where would you start?
New plugs and wires ect... also please let me know what brand is good.
I have read alot here about the Optispark and I think that my be the problem.
Is there anyway to have it checked out?
Thanks for any help.
Randy
Old Jan 9, 2007 | 01:23 PM
Your OBD-II PCM includes the capability of counting misfires by individual cylinder number. If you have the PCM scanned with an OBD-II scanner, with "GM Enhanced" parameter capabilities, it will tell you which cylinder(s) are misfiring. That might point you in the correct direction.
Old Jan 9, 2007 | 01:28 PM
2tight's Avatar
I just had it Inspected and they told me it was misfiring on #2 and #5 What would you think? thanks for the reply.
Old Jan 9, 2007 | 01:32 PM
2000GTP's Avatar
I would start with the easy stuff and make sure the plugs and wires are in good shape.
Old Jan 9, 2007 | 01:37 PM
2tight's Avatar
Thats sounds good. Are Taylor 8mm a good choice and for plugs what do you like?
Old Jan 9, 2007 | 01:42 PM
2000GTP's Avatar
I've had no problems with Taylor wires and NGK plugs.
Old Jan 10, 2007 | 09:46 AM
Z-RATED94's Avatar
Same here, although some people don't care for the Taylors wres.
Old Jan 10, 2007 | 12:00 PM
Sweetred95ta's Avatar
I run Taylors and haven't had a problem with them. I would guess that plug wires have deteriorated and that is your misfire. Plugs and wires are never a bad idea. You might not be able to get the 8mm plug wires back into the stock wire location. I can't remember if they fit in the looms or not.
Old Jan 10, 2007 | 02:12 PM
2000GTP's Avatar
Very true, but on the flipside, I have heard criticism over the MSD sets as well. People need to realize you can have problems with the best of brands.
Old Jan 10, 2007 | 02:43 PM
SantaCruz163's Avatar
I ran autolite plugs in my stock LT1 and they were fine. I believe I used taylor wires as well. change plugs & wires to start, and see where you stand. It could be a possible opti issue.
oldschool
Feb 9, 2016 09:21 PM
mr28
Nov 23, 2014 10:51 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
FASTFATBOY
Jun 20, 2002 11:27 AM
