Heater Core is BUSTED, anyone know how to bypass or replace???
Old Apr 14, 2003 | 02:03 PM
BlackLT1_TX's Avatar
I thought it was going, but today verified it, there is a puddle in my passanger floor board. Went out just in time for summer
So, anyone know where the heater core gets its water from, and if I can just connect the hose going into it and out of it?
Or, is it real hard to replace??
Thanks,
James
Old Apr 14, 2003 | 03:11 PM
ttt
Old Apr 14, 2003 | 03:17 PM
i know, but where are the hoses?
Old Apr 14, 2003 | 04:59 PM
mike95z28
Guest
Posts: n/a
When looking in the engine bay look towards the passenger side back to the fire wall. It's right there.
Old Apr 15, 2003 | 12:54 AM
Laymaster's Avatar
replacing it is fairly simple...you have to take apart underneath the 'glove box' and take out the black plastic box, the heater core is there. it's just a lot of wiggling. should take no more than an hour..maybe 2 if you have a lot of trouble wiggling it. Don't forget to get a new gasket for the heater core, otherwise your heat will be pretty weak in the winter time.
Old Apr 15, 2003 | 01:59 AM
surfinmud's Avatar
Go to a parts store and grab a U bend, or a few 90 degree bends and some clamps. Then take the two heater hoses going into the passenger side from the engine and connect them. Temporary, but effective.
Old Apr 15, 2003 | 04:08 PM
grygst76's Avatar
If you bypass the heater; be prepared for hotter temps at least from what I saw when I did it. Another word of advice is do not reconnect the little connector that holds the two heater core lines together so if you have to replace it again you just disconnect and reconnect---
alex5366
Mar 8, 2015 11:32 AM
alex5366
Feb 17, 2015 10:43 PM
kksi
Feb 17, 2015 10:41 PM
Britbilly
Jan 7, 2015 08:49 PM
Black93lt1
Nov 21, 2014 07:30 PM
