heat related starting problem
Old Apr 19, 2009 | 08:33 AM
one bad Z28's Avatar
I have been having a random starting problem with my 95 camaro Z28 almost every year once the weather gets above 70 degrees. Yesterday I went to start my car and when I turn the key nothing happens, no cranking or anything. I know the batterys fully charged. I cant seem to figure out why its doing this because it usually starts immediatly and never once have I had this problem when it wasnt hot outside.
Old Apr 19, 2009 | 09:56 PM
any LT1 experts on here?
Old Apr 20, 2009 | 05:08 AM
Guest47904's Avatar
Guest
Either trudge through the wiring inch by inch when it's warm out or. Get some freeze spray on a hot day and cool down certain things one at a time until you find the item that lets it crank once frozen.
Old Apr 21, 2009 | 07:52 AM
What is that freeze spray your talking about?
Old Apr 21, 2009 | 04:51 PM
Guest47904's Avatar
Guest
It used to be available at Radio Shack years ago
http://www.newark.com/itw-chemtronic...ray/dp/00Z1135
check a local electronics supply house
Here's one that's cheaper.
http://www.southernhillscomputer.com/mufrsp10.html
If that's too expensive you can do the opposite. On a very cold day, use a hair dryer to heat up the suspect components.
I'de start with the ignition switch
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 23, 2015 01:13 PM
Injuneer
Dec 15, 2014 09:36 AM
cristian1311
Nov 23, 2014 02:22 PM
JSK333
Sep 9, 2002 10:33 PM
