Pacesetter bolts ok for use?
Old Apr 21, 2009 | 01:48 AM
udlose94z28's Avatar
ordered a set of LT's with the 1406 gaskets ans was wondering if i could get by with using the supplied bolts? maybe put a lockwasher on them or no? Anti seize is going on the threads no doubt though
Old Apr 21, 2009 | 07:24 AM
sleeperLT1Z28's Avatar
I used them on my car. No lock washers needed, just tighten them up every so often. The only complaint I have is the heads rust.
Old Apr 21, 2009 | 08:47 AM
Rising Phoenix's Avatar
I used them on my car too, no problems yet.
Old Apr 21, 2009 | 02:24 PM
silentsprintero's Avatar
I had them on until a couple weeks ago. I ordered new gaskets (1406's) and ARP 1" 12pt 5/16" bolts. MUCH easier to get a wrench on the head of the bolt on every bolt. IMHO worth the $30, plus they are stainless.
Old Apr 21, 2009 | 09:27 PM
The_Bishop's Avatar
What he said. Get the ARP bolts. Especially the 1" version, as the 3/4" long ones provided don't really grab enough threads in the aluminum cylinder heads. Forget the fancy locking bolts; carry your wrench with you in the car and snug the bolts down every time the motor cools down. I did this for a week, and after a while you'll notice that the bolts stop snugging down after a bit; this is the gasket finally taking a 'set'. After doing this your header gaskets will live a long, happy life. I just check mine at oil changes now, haven't had a loose one yet.
Don't forget the anti-seize on the bolts, too.
BLK1997Z28
May 7, 2015 03:01 PM
drptop70ss
May 4, 2015 08:22 PM
racecarz28
Mar 30, 2015 09:55 PM
maybe2fast
Mar 16, 2015 09:45 AM
