heat range of plugs
Old May 4, 2004 | 11:07 PM
grygst76's Avatar
heat range of plugs
To me this is advanced only because it is a serious question, what spark plug should I use running a 306 cam; ported and polished heads with 200cfm maximum flow at .600; no cats into headers and no air.... colder or hotter? and what brand/type of plug??
Old May 4, 2004 | 11:49 PM
Stephen 87 IROC's Avatar
http://www.centuryperformance.com/spark.asp
Old May 5, 2004 | 06:21 AM
Re: heat range of plugs
200 cfm maximum flow (intake??) sounds a bit low.
General guideline is reduce heat range one step for each 75HP added. An Autolite 103 (2 steps colder than stock) should work. But in any case you need to check them after running them for a while to see if they are correct.
Routine LT1 Tech...... moving it there.
Old May 5, 2004 | 07:34 AM
grygst76's Avatar
Re: Re: heat range of plugs
WhoopS!!! I meant 280cfm @.600
grabbem88
20
Dec 27, 2015 07:42 PM
May 1, 2015 01:14 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Jan 23, 2015 01:13 PM
TrouserSnake
Jul 18, 2002 09:15 PM
