Heads and pistons.
Old Jun 30, 2007 | 12:38 PM
my94blackz's Avatar
Heads and pistons.
For a nitrous engine, would you want small chambers in the head with dished pistons, or would you want larger chambers with flat top pistons? IE: -10 piston with a 47CC head or -2 piston with a 56cc head?
Say you want to keep the compression around 12:1 would you want a deep dished piston and small head chamber?
Old Jul 1, 2007 | 04:22 AM
sssalah's Avatar
The ideal piston to use for good flame travel is a flat top. It wouldn't be a good idea to bring down the chamber volume from 56 to 47, that's requires milling 0.07" from the head. Production heads don't have thick decks so you'll be left with a week head which will not work well with nitrous. Even on aftermarket heads with thick decks, milling that much will hurt the head flow capability.
Old Jul 1, 2007 | 06:21 AM
rskrause's Avatar
Moderator
Are you talking a max effort nitrous motor or just adding some nitrous for an extra kick? In the latter case, it pretty much doesn't matter. If it's a max effort nitrous motor, there is a lot to consider - too many variables to really generalize. But the biggest area of concern is not how to make the power - it's how to keep the thing together.
Rich
Old Jul 1, 2007 | 07:54 AM
my94blackz's Avatar
Lets say a 396, with AFR 215's and a 250 shot. What piston and chamber size would be ideal. I want all I can get on the bottle.
Old Jul 1, 2007 | 10:47 AM
rskrause's Avatar
Moderator
Doesn't matter - any combination that gets you the desired CR will, for all practical purposes, give you the same result.
Rich
Old Jul 1, 2007 | 10:25 PM
One problem with deep dish on the pistons is the thinner piston crown. For a big shot of nitrous, you want a strong crown. Flat tops will provide that strength easier than a deep dish.
Old Jul 1, 2007 | 10:34 PM
rskrause's Avatar
Moderator
Amen to sturdy pistons! You don't want to see this:
However, there are pistons designed for forced induction/nitrous with a dish. JE, for example, has a whole series of them as do the other big piston manufacturers. I will venture the opinion that the power difference between a properly designed flat top, dish piston, or a small dome in your application will be very small. A percent or two at most.
Rich
Dmonty
Jun 2, 2015 11:19 PM
Rde Bandit
Mar 21, 2015 10:17 PM
9t4lt4z28
Parts Wanted
Mar 11, 2015 09:14 PM
Roadie
Feb 16, 2015 10:34 AM
Queens94z28
Nov 20, 2014 06:03 PM
