heads/cam/timing chain install
Old Jan 17, 2012 | 07:05 PM
V8 LifeStyle's Avatar
hey guys I need advice on how to line everything up. The timing chain cam sproket came off the cam because the bolts snapped,( Im gonna use APR bolts) So i have new cam/ timing chain set with sprokets and new heads. I have spun the crank around alot. So its not where it left off, how do i line up the cam and the crank so when the chain/sproket goes on its all lined up.
thanks alot guys
Old Jan 17, 2012 | 08:31 PM
Re: heads/cam/timing chain install
The info in this link will tell you how.
4th Gen LT1 F-body Cam Install
You really should have had a good reference on hand before starting this project.
Old Jan 17, 2012 | 10:55 PM
thanks it helped alot wasnt as complicated as i thought
thanks again
Nov 18, 2023 07:21 PM
Sergio
Jan 27, 2016 04:27 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Queens94z28
Dec 20, 2014 09:11 PM
GigaMp3z
Feb 20, 2003 02:57 PM
