heads cam install videos?
im looking for some videos on how to do heads/cam swap if anyone knows of any for my 96ss. all top end will be new. i just need to know a few things like people talk about TDC when lining up the cam to timing chain, adjusting the valves, just the technical stuff.
You won't find anything LT1-specific in terms of videos (at least none that I know of), but there are a few heads/cam install guides floating around. You should find tons of info on the forums. Check out shbox.com for starters.
Also if you don't have it, a Chilton's/Haynes manual is a good reference tool.
Yup, just follow the one on shoebox's site.. That's what I used tow yeas ago.. Did my first cam swap in 07/08 winter.. Now I've built 3 LT1's and 2 LSx motors... All I did was started with a cam swap in my camaro following Shoebox's site. Now it's just second nature.
F(ast)-body
Feb 26, 2003 09:05 AM
