Headers and O2 sensors
Old Oct 14, 2003 | 10:46 AM
WhtLT1's Avatar
Ok I'm lookin to put in some Hooker LT's soon and was wondering if I should replace all 4 of my O2 sensors with the dummies, or keep the two on the headers and just replace the back two with dummies? ANother thing, I'm goin to be deleting my cats too. And the car is a 96 with the dual cat setup and OBDII. Thanx
Old Oct 14, 2003 | 11:11 AM
You can not easily delete the two "pre-cat" sensors. The PCM needs the feedback from these sensors to control the air/fuel ratio. You could remove them and run open loop, but that is generally not a good idea, producing poor fuel mileage and potential rich or lean problems. The PCM will not be able to respond to modifications.
If you delete the cats, you must either use the "sims" in the two "after-cat" positions, or you need to have the after-cat sensors programmed out of the PCM.
Old Oct 14, 2003 | 02:15 PM
revtime's Avatar
Just order some Jet Hots with the O2 bungs welded in and get some extensions for the O2 sesors, makes life alot easier.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
