Headers an exhaust
Old Aug 23, 2011 | 04:46 PM
Moobz290's Avatar
Headers an exhaust
This is my first 94 z28 lt1 an when I do my headers what's the hoeses that r hooked up to tge manifoldswhat do I so with this becuz the headers I have don't have those an the sencer by the cat is that important or just keep it unplugged I have true duals from a ls1 I'm welding on but idk about all the sencers an ****
Old Aug 23, 2011 | 05:37 PM
frankzlt1's Avatar
Re: Headers an exhaust
the censers are o2 censers you definitely need the one before the cat the one after the cat you will not need but you might have a ses light on until you get a o2 simulator or program it out.i think on the 94's the y only has 1 cat. the other hoses on top are the smog air pump and you dont need to put them back on depending on your emissions in your state (you shoulded get a ses light for the air pump but i might be wrong) if they require you to have it connected( if they look at that part of the emissions.) also you may have to have cats on your duals depending on your states requirements.
Old Aug 23, 2011 | 05:42 PM
frankzlt1's Avatar
what type of headers are you going to use. and how are you planning on installing them, because the long tube headers are not fun. how i did mine was lifted the motor and that was easy for me but still a pain. also watch out for the water temp censer on the drivers side head you will probably break it off you might want to pick one up and when you change it have the other one ready to go in as you take the old one out not much anti freeze will come out.
Old Aug 23, 2011 | 06:08 PM
6SpdLT1Z's Avatar
Are you talking about EGR/AIR or o2 sensors? It would help if your post was more readable.
Old Aug 24, 2011 | 05:25 AM
Sensor
You have a pair of O2 sensors, one in each branch of the Y-pipe, before the single cat. You generally want to keep those, because the PCM uses them to control the A/F ratio. You could delete them by running an open loop tune, but I don't think you want to do that.
AIR and EGR connections can be deleted. As long as you have a good fuse in the AIR pump circuit, no code. But you will get a code if you delete the EGR vacuum solenoid, and another for the missing EGR flow. The codes can be eliminated by tuning them out.
Old Aug 24, 2011 | 06:51 PM
Moobz290's Avatar
Yeah I no a guy that gets my inspection stickers soi don't have to do emission ****
Old Aug 24, 2011 | 07:29 PM
Moobz290's Avatar
I have long tube an there a bitch I read u have to take vvalve covers an steering **** out I started am seen all the sencer an the hoeses on the headers an gave up till I can find out what ineed to do with then like indicator lights on dash don't matter its already lite up like a a tree that's y I have a guy I get inspection stickers from
Old Aug 24, 2011 | 08:03 PM
6SpdLT1Z's Avatar
You can get emission block off plates if the long tubes you have don't have emission provisions. You can also get a mail order tune to tune out those components so that your dash doesn't "lite up like a a tree."
I did not need to take the valve covers off for my long tubes (Pacesetters) and some long tubes don't require the steering column to be disconnected from the knuckle.
Your complete lack of respect for the English language makes my head hurt. If you spend a few minutes proof reading your posts, you'll most likely get more help from more knowledgeable people than me who gave up trying to comprehend your posts.
Old Aug 24, 2011 | 09:27 PM
Moobz290's Avatar
[QUOTE=6SpdLT1Z;6768666
Your complete lack of respect for the English language makes my head hurt. If you spend a few minutes proof reading your posts, you'll most likely get more help from more knowledgeable people than me who gave up trying to comprehend your posts.[/QUOTE]
R u for real taking **** over a message board I'm on my phone at work when I have a sec so that's y its not perfect language sorry bro
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
drptop70ss
May 4, 2015 08:22 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
92ragtop
Dec 27, 2014 01:56 PM
