Headers burned everything...where to get new wiring harness??
Old May 31, 2005 | 01:32 PM
Robbie's Avatar
I developed a major hesitation about 6 months ago and found that my Longtubes had burned and cooked my wiring harness on the passenger side. I think the wires go to the o2 sensors, starter, etc. Is there a way I can get a whole new harness all together? BTW, back when i found the problem I rewired everything but not with the correct gauge wires. Suprisingly my car still runs fine but I want to do it the right way.
Old May 31, 2005 | 01:39 PM
sssalah's Avatar
Re: Headers burned everything...where to get new wiring harness??
The new harness can be bought new from GM but is expensive. Might want to try getting used harness and inestigating why this happend in the first place.
Old May 31, 2005 | 04:15 PM
mongse_1's Avatar
Is it the engine harness or the body harness? I have the engine harness out of my '95 sitting in a box and may have the body harness available soon too. Let me know if you're interested.
Old May 31, 2005 | 04:20 PM
Gripenfelter's Avatar
I need a new one for a 93 A4 LT1 as well.
Just because mine looks like crap.
Old May 31, 2005 | 05:30 PM
96flame's Avatar
I rerouted my harness down the front of the strut tower and inside the motor mounts to get away from burning the harness. As long as you used larger wire than what was there to repair it just drive on. If you used smaller wire then you'll want to replace that. In my opinion if you put a factory harness back in it will just be burnned up in no time again. Theres not enough clearance between the headers and the harness to avoid that.
Old May 31, 2005 | 09:48 PM
revtime's Avatar
Just start where you still have good wire left and extend those wires and route them away from header heat.
Your going to have to do it anyway, so just go up the harness till you get good, unburnt wires, extend to the length you need and then rewrap them with convoluted tubing.
This is why I spent several days extending and rerouting wires and such so they would be away from header heat.
Old May 31, 2005 | 11:17 PM
Heatmaker's Avatar
Advanced Member
Last time I walked into the dealer and got a price on the wiring harnes... it was $1XXX.XX and I laughed and so did the parts guy. I would just re sauder everything back with the right wires... trust me... You'll be asking yourself... spend 600.00 on a new PAinless LT-1 wiring harness also found on "EBAY" where people sell LT-1 harness and stuff like every day for dirt cheap! ... or shoudl you spend like 5 bucks at radio shack and get it done right there.
Old May 31, 2005 | 11:27 PM
lookingforwheels's Avatar
Ugh, my harness started to burn but luckily i caught it the nest day and none of the wires got melted, just that black plastic around though. All though the weather pack connector for the 02 is destroyed.
Jul 4, 2005 05:00 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
CobraEatr
Jul 23, 2002 06:32 PM
