header recommendations
I want to put on headers on on formula, it's an LT1, most likely some shorties since I need to pass emmisions , I was thinking on the Mac headers.What headers would you guys recommend?
Re: header recommendations
I have mac headers and they are pretty awesome. Keep in mind that just because the headers have emissions hookup it doesnt necessarily mean you will pass smog if the guys are **** since they do not carry a CARB#
I am really deciding towards the Mac mid lengths but do they make them ceramic coated, also another question, should I have a problem installing them since the very last bolt on my passenger side manifolod(on the #8 cyl.) broke off and the remainder of the bolt is still on the cyl. head, but I heard that headers dont use that bolt hole, they use the one on the right of the one that the manifold uses.Is this true?
The Macs are the only headers I've seen that use the outer bolt holes, i.e. the same ones that the stock manifolds use.
You could drill 4 new holes in the header flanges if you want to use the same holes and gaskets that most headers use. Or just drill the one that's a problem.
Formula where are you from first of all? All depends if they have the visual inspection in your state. Don't have it here in MD. Im running Pacesetter LT's with offroad Y with no problems. Also I had the same problem with my header bolt breaking off in the heads. Forced me to do a head/cam swap.
I'm from S.California and emmisions is stiffer out here.And I had posted my problem about that last bolt on the passenger side(on #8 cyl) breaking off, and a member said that headers dont use that bolt hole that they use the one next to it.Also since I'm going to take off the manifold to see if I can get that bolt out, hopefully a piece of it is hanging out of the cyl. head so I can try to use some WD-40 and like some vice grips to get it out.Since I'm gonna go through all that trouble I might as well put on headers since I'm already there.
Yeah HOPEFULLY it doesnt use that bolt hole. More then likely, with the aluminum heads, that hole is stripped out and will have to be retapped. The way our motors sit back so far its nearly impossible to put in a heli-coil in with the heads on the car.
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
