Header questions..need ground clearance ,good plug access..
Old Sep 4, 2005 | 12:07 AM
  #31
Z95m6's Avatar
Re: Header questions..need ground clearance ,good plug access..
Originally Posted by BADST95
FLPs have better ground clearance than Hookers when installed correctly. The v-clamp MUST be installed in the correct position (without the t-bolt clamp facing down). Yeah... my car must be different. GM built my car differently from the rest of the 4th gen LT1 f-bodies. If anything, my ride height is lower than stock since I have QA1 adjustable shocks and race springs (lower spring rate). I lowered the car in the front via the springs and I even removed the rubber spring isolators and wrapped the top of the spring with rubber heater hose to give the rear a lower stance. When the headers were fit on my car, I went over speed bumps, median strips, poorly maintained roads, etc, to test the ground clearance. Since that time, I now use a custom 3 inch into 4 inch y-pipe and I still can't get the exhaust to scrape. I even pull the front end off of the ground at the track and the headers or over-sized y-pipe don't hit the ground when the car comes down. It must be magic.
As far as i know FLP's aren't even made anymore (i don't pay constant attention to this as i don't need headers) so thats not really an option for people.
Old Sep 4, 2005 | 12:09 AM
  #32
FastZinTennessee's Avatar
My single cat style SLP headers worked out really well for me. I burned one plug wire, but after switching to over the valve cover wires no more problems. Plug access is crappy, but better than stock. The headers have not burned or melted anything else in the engine bay. I don't like how the headers attach to the Y-pipe at all, but that's about my only gripe. I'll be switching to some Hooker LT's with a Y-pipe.
Old Sep 4, 2005 | 12:17 AM
  #33
BADST95's Avatar
Smile Re: Header questions..need ground clearance ,good plug access..
That is true. They are no longer made. I never said to buy them as I know that they aren't made. I was just giving an example.
However, you still can purchase the race version of these headers from Dynatech. They have slip on collectors.
Old Sep 4, 2005 | 12:19 AM
  #34
blind527's Avatar
Does FLP headers= Finish Line Performance headers, or are they a division of SLP? I only ask that because I know some people with FLP headers, and didn't know if they were any good or not.
Old Sep 4, 2005 | 12:29 AM
  #35
Z95m6's Avatar
yeah FLP's are finish line performance. I've always heard that plug access is impossible on some of them and that people have had trouble with the collectors hitting the floorboards sometimes.
Old Sep 4, 2005 | 12:32 AM
  #36
blind527's Avatar
Ah I used to live by their shop in Naperville, like 30 minutes away Meh, what can you do.
Old Sep 5, 2005 | 01:33 PM
  #37
-vellu's Avatar
Good ground clearance:
http://www.transam.fi/images/Ground%20Clearance.jpg
I just installed Ceramic Coated Arizona Speed and Marine headers (mid tube, 4:1 header single cat. w/Y-Pipe Constructed of 14 gauge steel with 3/8 flanges. 1 3/4 inch primary tube. HPC-coated (inner & outer surfaces). Y-pipe HPC cermaic coated inside and out. Random Technology High-Flow Catalytic Converter and Magnaflow Cat-back.
Car is dropped two inches with intrax springs and KYB AGX Adjustable Shocks.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
ModdedNerd
Jan 1, 2015 10:56 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
