Header Problem
Old Nov 9, 2011 | 10:41 PM
fiesh27's Avatar
Header Problem
Hey. So I have looked for an answer to this all night but couldnt find one. I have a 94 Camaro M6. I just installed a set of Pacesetter Headers. I just took it for a test drive and I have half the power that I had with the stock manifolds on. I blocked off the A.I.R port holes. I also unplugged the air pump. Can anyone help me?
Old Nov 9, 2011 | 11:30 PM
Bersaglieri's Avatar
Re: Header Problem
Did you change anything else? Did you burn a wire? What about EGR, what did you do with that?
-Dustin-
Old Nov 9, 2011 | 11:57 PM
fiesh27's Avatar
Re: Header Problem
The only problem that I had with the EGR is the tube that goes to the header on the drivers side would not line completely up. It has the bolt in it, but it leaks. I checked all the wires and they seem to be fine. It doesn't act like it is missing. It just cut the power in half. You don't think that going from 3 inch collectors to 2.75 pipe would be a problem?
Old Nov 10, 2011 | 12:00 AM
fiesh27's Avatar
Re: Header Problem
I meant the tube that goes to the header on the passengers side. Not the drivers.
Old Nov 10, 2011 | 12:14 AM
Re: Header Problem
If you have a leak at the header [EGR hookup] your oxygen sensors will read incorrectly and alter the air/fuel mixture which can make the car run like poop. Look into fixing your leaks.
Necking down a 1/4" isn't a big deal.
-Dustin-
Old Nov 10, 2011 | 04:33 AM
RamAir95TA's Avatar
Re: Header Problem
If there's no obvious mechanical symptoms then your power loss is likely psychological.
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
