Vacuum line location questions.
Old Nov 10, 2011 | 03:32 AM
SSinister11x's Avatar
Alright, I've been searching on this all night and hate to bother you guys but...here goes. I'm replacing some worn out vacuum lines on my 96 SS. I've run into a dillema with the EVAP lines. On Shbox site I noticed the Evap purge solenoid valve has it's top line running to the throttle body and the lower line going to the fuel line bundle which leads to the canister in back of car. When looking at my motor i noticed that my top line leading forward out of the solenoid goes to a circular black plastic looking thing and then out of it is the line that bundles up with the fuel lines. The bottom line running out of the solenoid goes to the side of the throttle body. Is this a problem? Do I need to switch them around? Appreciate any help as always.
Old Nov 10, 2011 | 06:45 AM
Re: Vacuum line location questions.
Yeah, it is backwards. It would still work (because the solenoid merely connects one line to the other). I'd put it right, just because I am **** about such things.
Old Nov 10, 2011 | 12:23 PM
As am I haha. Thank ya, wouldn't be able to find the radiator with out your site.
Feffman
Oct 9, 2015 05:42 AM
lt1matt
Mar 21, 2015 07:35 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
Patrick Kovack
Mar 8, 2015 09:26 AM
grgguy
17
Feb 23, 2015 07:57 PM
