Header Problem
Header Problem
Hey. So I have looked for an answer to this all night but couldnt find one. I have a 94 Camaro M6. I just installed a set of Pacesetter Headers. I just took it for a test drive and I have half the power that I had with the stock manifolds on. I blocked off the A.I.R port holes. I also unplugged the air pump. Can anyone help me?
Re: Header Problem
The only problem that I had with the EGR is the tube that goes to the header on the drivers side would not line completely up. It has the bolt in it, but it leaks. I checked all the wires and they seem to be fine. It doesn't act like it is missing. It just cut the power in half. You don't think that going from 3 inch collectors to 2.75 pipe would be a problem?
Re: Header Problem
If you have a leak at the header [EGR hookup] your oxygen sensors will read incorrectly and alter the air/fuel mixture which can make the car run like poop. Look into fixing your leaks.
Necking down a 1/4" isn't a big deal.
-Dustin-
-Dustin-
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
