Header modify???
Old Feb 24, 2018 | 10:15 AM
wideglide2011's Avatar
Header modify???
Are peaple welding these 2 piece header tubes????
If i cut this flange off will i be able to then use a slip fit off road y-pipe or will i be way off on dimensions??? Thanks for the help.
Attached Thumbnails Header modify???-20180224_090426.jpg   Header modify???-20180224_090436.jpg
Old Feb 26, 2018 | 10:47 PM
95LT4Z28's Avatar
Re: Header modify???
they look like hooker headers. if im not mistake the #1 pipe seperates from the rest of the header. the #1 tube is installed around the steering shaft after the rest of the header is installed. people put high temp silicone ( like permatex copper ) in the joint to seal it. i would buy a set of flanges and bolt up your y pipe. you ll destroy the coating if you weld to it and if you cut the flanges off you may have trouble getting a pipe to slip over.
Old Mar 1, 2018 | 09:47 AM
thanks for both replys. yeah there hooker headers but i don't remember the part number. i'll run them as is for now and see how it pans out.
Old Mar 1, 2018 | 03:38 PM
lt1-xjs's Avatar
You'll need a set of collector reducers. Do those have 02 bungs ? Flowtech 10004: Exhaust Reducer 3-Bolt 3" Collecter Flange Inlet | JEGS
Old Mar 1, 2018 | 07:25 PM
Exactly!
Old Mar 2, 2018 | 09:38 AM
yeah they have 02 bungs. the reducers are where i'm headed. just trying to get a start on exhaust lay out. thanks for info guys.
CANTONRACER
Mar 15, 2005 03:05 PM
poloz28
Sep 9, 2002 10:09 PM
Dan K
Aug 3, 2002 09:12 AM
slimdawson
3rd Gen / L98 Engine Tech
Jul 25, 2002 06:43 PM
Michael Ozorowsky
New England Area
Jun 25, 2002 07:32 PM
