header install any tips or tools that will help
Old Apr 7, 2008 | 02:51 PM
  #16
caldercay's Avatar
Originally Posted by Crows89RS
take out the oil pressure sensor. i broke [snipped]
Why did you break the oil-pressure sending unit? That's at the back
of the engine, behind the intake manifold - did you take the tranny
mount off and drop the tranny's tail end down? That's usually the
only way to break the oil-pressue sending unit (OPSU), because as
the engine tilts to the back, the OPSU bumps against the firewall and
gets borked.
Old Apr 7, 2008 | 03:04 PM
  #17
2000GTP's Avatar
gets borked.
Maybe he is thinking of the coolant temp sensor for the cluster gauge.
Old Apr 7, 2008 | 03:15 PM
  #18
caldercay's Avatar
Well, they did say, "take out the oil pressure sensor. i broke mine when
i did headers, as well as coolant temp sensor. "
So, I'm thinking the coolant temp sensor they're talking about is the
one on the driver's side of the engine. (The other one is at the front/
base of the water pump and supplies info to the PCM).
Old Apr 7, 2008 | 03:20 PM
  #19
2000GTP's Avatar
I don't know. I ended up breaking the coolant temp one as well, I tried to cut a corner and lost. Didn't have any run-ins with the oil pressure sensor.
Old Apr 7, 2008 | 04:52 PM
  #20
az0884's Avatar
You can get a set of header bolts from autozone for about $10 that come with wires with springs over them that you slide through little holes in the head of the bolts and it keeps the bolt from rattling out.
I highly recommend this because if your header comes loose and you blow out the gasket then you have to buy new gaskets and do more work.
Old Apr 7, 2008 | 05:30 PM
  #21
cmg06s's Avatar
if your tight on cash I would wait to install them, it took me a week to install my headers plus hundreds more beyond my original budget, due to eveything that could go wrong going wrong, bolts breaking, stuff not fitting, parts breaking etc.
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jlo
Feb 23, 2015 12:20 PM
ChrisFrez
Feb 22, 2015 08:47 AM
dmcdonald96
Jan 30, 2015 06:46 AM
