What does this wire go to? Connector.....
Old Apr 6, 2008 | 09:11 PM
Mike96z's Avatar
Alright, not sure where this connector goes but here is a picture of it, its under the steering column by the pedals. Not sure where to put it. If anyone has a pic of where it goes and to what it goes to, that would help. Thanks
Tan and black wire with white 2 pin connector i think.
Old Apr 6, 2008 | 09:14 PM
mdacton's Avatar
is it a 6spd.? I think its to the brake lights......
The one on the clutch pedal is bigger wires.
shbox will know
Old Apr 7, 2008 | 12:18 AM
Daniel6718's Avatar
vats i would say but i think thats a black connector
might be for the clutch switch
Old Apr 7, 2008 | 01:06 AM
Mike96z's Avatar
well its not brake lights for sure, thats a similar connector but black instead of white. I have looked and there is no open place to plug it in. Vats is working fine so dont see how that could be it. Nuetral safety switch works good too......... confused.
Old Apr 7, 2008 | 01:57 AM
acre's Avatar
I happen to have my car torn apart under there so I went and looked. I seem to have the same disconnected plug. Its a smaller plug, about 1/4 inch across with something like 18 or so gauge wire right? If I follow it up, its in the same wire bundle as the brake light switch.
If I had to guess, its probably something for an A4, and is not used on an M6. Isn't there a circuit to the A4 to tell it your foot is on the brake so you can shift into gear?
Old Apr 7, 2008 | 07:10 AM
Mike96z's Avatar
probably.......... some people are telling me that its the trunk release button wiring but thats in the glove box, unless its an extra because i think the t/a has it under the steering column.
Old Apr 7, 2008 | 07:25 AM
Isn't there a switch on the clutch that releases the cruise control when you push down the clutch? Can't go check it, because somehow my clutch pedal seems to have disappeared . But I thought there were two switches on the clutch.... on for the start interlock and one for the cruise release.
Old Apr 7, 2008 | 08:29 AM
Mike96z's Avatar
ill check that out again but i seen the clutch connector plugged up.
Old Apr 7, 2008 | 10:39 AM
AHARTZ28's Avatar
it looks like the brake shift interlock solenoid used on A4 cars
Old Apr 7, 2008 | 10:49 AM
Dave1980's Avatar
I believe I have that same wire loose underneath??? I am not sure what it does. I will have to check again.
Old Apr 7, 2008 | 05:02 PM
az0884's Avatar
Mine is disconnected as well and everything in the car seems to work fine.
Maybe its supposed to be that way?
Old Apr 7, 2008 | 06:02 PM
<Puck>'s Avatar
I believe so.
Way back when I did my gauges I noticed it hanging there under the dash and not connected to anything. Tried to trace it back but it just gets lost in the rest of the wires.
My battery is out of my car right now while it is worked on, but maybe someone can turn their car on and check both sides of the connector with a multimeter to see if it gets any voltage or is just a dead factory connection .
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
