Header gasket change HELP!!!
Old Jan 20, 2005 | 04:58 PM
SS#771's Avatar
Alright I changed the driver side gasket with no problems at all. But the passenger is a whole different story. I have lost 2 things now down inbetween the header where it splits and then goes to the collector. So i have on of my bolts down in between where it goes into the collector. I am now trying to get the passenger side header out. It doenst want to come out at all...I have tried everything an nothing seems to work... I use to have an a4 transmission and it seemed to have gone in easier...and now the the bellhousing on my m6 seems to be getting in the way? I cant seem to angle it out just right....can someone please give me some suggestions on doing this??
Old Jan 20, 2005 | 05:13 PM
My93Z's Avatar
Re: Header gasket change HELP!!!
I used a thin piece of wire to stick between the primaries and pushed the bolt back up intil I could grab it. I found some old windsheild wiper blades and took out the thin metal part in them. I guess might even beable to use a cloths hanger. I hope this helps
Old Jan 20, 2005 | 05:15 PM
PurplePonyEatr's Avatar
I agree... I'd try to fish it out before taking the header off... If you do have to take it off though, Jack up the motor a little, it helps tons...
Old Jan 20, 2005 | 05:23 PM
TUFF LT1's Avatar
I went to the store and got one of those extendable magnet picker-uper things. $3 and is works great.
Old Jan 20, 2005 | 05:27 PM
SS#771's Avatar
no way a coat hanger is going inbetween the primaries. Is there anything i should know about raising the motor on one side??? I dont want to get into any worse trouble than I am now.
Old Jan 20, 2005 | 05:33 PM
SS#771's Avatar
i have one of the magnet things already..way to thick to go down there.
Old Jan 20, 2005 | 05:48 PM
SS#771's Avatar
ttt
Old Jan 20, 2005 | 06:15 PM
SS#771's Avatar
anyone else????? i could really use some advice
Old Jan 20, 2005 | 07:06 PM
TUFF LT1's Avatar
take some .041 safety wire and make a electro magnet and pull yank it out with that. Or maybe wind up some duct tape into a long strand then get it down in there as best that you can and stuff it in. Then give her a pull! Don't get the tape stuck...it will smell later. Good luck man.
PCLZ28
Dec 24, 2015 05:19 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
birdblack
Dec 30, 2014 06:59 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
