header bolt wont fit... primary in the way
Old Sep 3, 2005 | 02:51 AM
ttop1986's Avatar
Hey, I got pacesetter long tubes im putting in, and the farthest primary to the front of the car will not alow me to get me header bolt in. Like the bolt seems too long and hits the primary not allowing it to go in the hole. The primary is in the way. What have you guys done to get this 1 bolt in? Thanks. O yea and if it matters, they are 1 " breslin bolts.
Old Sep 3, 2005 | 02:57 AM
ChevyTuffD.A.'s Avatar
Re: header bolt wont fit... primary in the way
If your talking about the driver side header then u have to pretty much put that bolt in first. Either that or make sure the other bolts are out far enough to be able to move the header around a little bit. When I was installing a set of Pacesetter headers on my buddys car I had to call my friend (who also had the Pacesetters on his car) and ask him how he did it bc I couldnt get it to fit in either. Try to get it in as a discribed above and u should be able to get it to go in. Dustin.
Old Sep 3, 2005 | 03:58 AM
blind527's Avatar
I had the same problem with my Jet Hot's on my passenger side. I actually had to use a seperate bolt that was the same tread size and length, but only it was round and has to use an allen key. I like the way it fits in there.
Old Sep 3, 2005 | 07:25 AM
ss97dml's Avatar
cut it down
Old Sep 3, 2005 | 01:19 PM
3gc's Avatar
3gc
I ended up using a 3/4" header bolt for that one spot instead of the 1" long ones .
Old Sep 3, 2005 | 03:38 PM
ttop1986's Avatar
I got it in today. I had to loosen the other bolts so the header could pull away from the head allowing a little bit more room. Had to also go to sears and buy a new little wrench to fit on it though. Thanks for your input guys!
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
