Header bolt fell out!
Old Jul 17, 2014 | 04:22 PM
Greg88's Avatar
So one of my middle header bolts fell out and I drove the car for about 10-15km. I think it's a fiberglass gasket. I put the header bolt back in, and it still sounds like an exhaust leak. Did it maybe burn the gasket up while it was loose? Also number one Cyclinder header bolts were loose aswell.
Old Jul 17, 2014 | 06:50 PM
parkers Z28's Avatar
Re: Header bolt fell out!
I would replace the header bolts when you replace the gasket
Old Jul 17, 2014 | 07:40 PM
Greg88's Avatar
I already replaced the bolt and it's still ticking
Old Jul 18, 2014 | 12:04 AM
Chimera96's Avatar
you probably burnt the gasket. just replace it. You need to re-torque header bolts after a few heat cycles of initial install......and not a bad idea to check them periodically
Old Jul 18, 2014 | 01:27 AM
97WS6SCharged's Avatar
If you put a bit of teflon tape around the threads they won't back out quite as easily.
Old Jul 18, 2014 | 09:14 AM
Use good gaskets (Fel-Pro 1406) and good bolts (ARP) to minimize the problems. The stuff that comes with a set of headers is usually poor quality.
Old Jul 18, 2014 | 11:10 AM
Greg88's Avatar
Ok thanks guys!
Old Jul 19, 2014 | 07:59 AM
Greg88's Avatar
Ok I have pacesetter headers and afr heads. They have the mr gasket gaskets which the ports are round and they have the fel pro ones that are square. All 1 1/2". Which do I go with?
Old Jul 21, 2014 | 09:45 AM
RUDEDOG's Avatar
D-ports.http://www.summitracing.com/parts/fe...-size/5-7l-350
Old Jul 21, 2014 | 03:36 PM
The Mr. Gasket CopperSeal are also available in D-port #7154
Old Jul 21, 2014 | 05:16 PM
bw_hunter's Avatar
I used a set of Stage 8 locking bolts and never had the problem again....
Old Jul 25, 2014 | 09:31 PM
Greg88's Avatar
So my local auto parts store ordered me fel pro 1404 gaskets not the 1406, wil they still work?
Old Jul 26, 2014 | 01:35 AM
Fatdog2's Avatar
After market headers have to be tightened at least once a year.Got this from a a master mechanic.Hope this helps.
Old Jul 26, 2014 | 07:31 AM
bw_hunter's Avatar
1404 are the standard SBC port shape, the 1406 are the D shaped port shape that your engine has. They'll bolt up but I think there will be gasket material sticking into the port. Why not get the right ones?
Old Jul 27, 2014 | 05:18 AM
Greg88's Avatar
Yea I took the 1404 ones back and got the right ones yesturday! Thanks guys
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
