Head flow
Old 02-18-2007, 07:01 PM
mdacton's Avatar
Trick flow vs. stock casting
will a trick flow head out of the box out flow a ported LT1 head?
mdacton is offline
Old 02-18-2007, 07:11 PM
Z-RATED94's Avatar
I don't believe so. What are your plans, seeing as how the combustion chambers are quite a bit larger?
Z-RATED94 is offline
Old 02-18-2007, 11:55 PM
TFS has flow numbers on their website. The LT1 heads are basically their reworked Gen 1 SBC heads, so I think they use the same flow numbers. That also explains why the Trick Flows have the larger 62cc combustion chambers, compared to the 54cc stock LT1 heads.
Injuneer is offline
Old 02-20-2007, 02:33 PM
94_camm's Avatar
i have a set of trickflows..then got them ported by lloyd.they flow pretty good at 298
94_camm is offline
Old 02-20-2007, 02:45 PM
Colin91Z's Avatar
Very True.
I have Trickflow's catalog right in front of me. The flow #s for the 195cc LT1 heads is identical to the 195cc SBC heads.
Direct from Trickflow's catalog...
Tests conducted at 28" of water (pressure); exhaust with 1 3/4 pipe.
-----------I / E
.100-----51 / 58
.200----136 / 98
.300----191 / 136
.400----230 / 163
.500----253 / 177
.600----254 / 190
...so to answer the original post:
If the factory LT1 heads have been ported by a reputable porter (LE, AI, TEA, CHS, etc...) Then No, the trickflows will not out flow them out of the box. However, when ported (once again: by a reputable porter) they can outflow the factory castings.
Colin91Z is offline
Old 02-20-2007, 07:03 PM
mdacton's Avatar
after searching all the flow numbers I'm just going to get a set of 374's ported.
I don't have the money for trickflows plus porting so I thinks the stockers will do what I want
mdacton is offline
Old 02-21-2007, 08:51 AM
Z-RATED94's Avatar
Not that anyone should give a crap of what I think, BUT that's what I would do.
Old 02-21-2007, 08:54 AM
Moderator
Javier97Z28's Avatar
Most likely, plus you'd need to mill the TFS heads a good bit to get the CR back up to where it should be.
Javier97Z28 is offline
Old 02-21-2007, 09:35 AM
mdacton's Avatar
At this point it is probly my best option....I don't see dropping a few g's on LT1 heads......
If all goes well i'm going to just buy a new engine 434 SBC
mdacton is offline
DirtyDaveW
03-15-2015 07:01 PM
Roadie
02-16-2015 10:34 AM
MadMav
02-06-2015 11:02 PM
95chwagon
01-13-2015 09:19 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
Quick Reply: Head flow
