having problems.. possibly optispark
Old Sep 13, 2006 | 12:34 AM
Purplemaroz28's Avatar
It only happens at night when its cold, but itll stumble in first gear and it is defintiley missing. At idle u can hear it stumbling. And it defintley smells rich. Is this just as fouled plug or wire or do i have the opti spark blues.. no problems during day. by the way the optispark is new with the engine and so are all the spark plugs and wires and my a/f is roughly 13.7-15.1 at idle. and 12.8 at wot
Old Sep 13, 2006 | 12:21 PM
Re: having problems.. possibly optispark
Originally Posted by Purplemaroz28
It only happens at night when its cold, ....
When the ambient air temp is cold, or when the engine is cold, or both?
Old Sep 13, 2006 | 01:55 PM
it only happens when the outside tempature is cold and after the engine has warmed up. But then this also only happens EVERY now and then and is not a contioniouse problem so it is hard to have a mechanic diagnose it.
Old Sep 14, 2006 | 04:16 PM
Guest47904's Avatar
Guest
Pull the coil off and inspect it closely for any white marks on the black insulation or cracks. You could also mist it with a spray bottle of water to look for sparks at night.
You should also scan it to see what the sensor readings are doing from cold to hot like ECT or IAT.
Old Sep 17, 2006 | 10:30 PM
any more advice trying it tommrow
Old Sep 18, 2006 | 05:03 PM
my passenger side o2 is alittle lazy going to replace that and see if there is any difference. Still trying to get cable for scan.
KYWes
Jun 14, 2022 06:52 AM
Jeff1904
Jun 5, 2016 05:00 PM
Ericksd
Jan 20, 2016 06:07 PM
Z Power
Sep 19, 2015 11:19 PM
jackpawt883
Sep 10, 2015 08:53 PM
